Using Pebblekit Js Configuration
  • 21 November 2013
  • #makeawesomehappen, Beautiful Code
One of the most useful additions to the Pebble SDK in the 2.0 beta release is the introduction of PebbleKit JS and the ability to use a webview on your phone to configure your watch app. Since we've been seeing a good number of questions on this new feature, we figured we'd talk about it a little more.
What is PebbleKit JS?
PebbleKit JS is a new library in the Pebble SDK that allows your watch to communicate with the rest of the world/internet from within the Pebble mobile app itself. This means you don't have to have Android or iOS-specific knowledge in order to interact with web services or to create configuration interfaces on your mobile phone.
What is the JS configuration utility?
The JS configuration utility allows you to create a configuration interface for your users to access on their mobile phones. You can use this to collect user information and credentials, or to create a place where users can adjust settings in your app. For example, in 1.x, a lot of duplicate apps were created to handle variations in languages, different watchface appearances, and time formatting. With the new JS config utility, you can setup a webview for your users to configure their preferred language, their preferred date format, and any variations you want to allow in the actual appearance of your watchface.
How do I use it?
Using the JS config utility is very easy! To get started, read App Configuration.
Thomas also created a cool demo of the configuration utility on GitHub.
What now?
Not sure how to implement a JS configuration view? You can also try out the nifty SetPebble site, which auto-generates your JS webview for you based off of values you enter on the SetPebble site.
The instructions on how to do this can be found here
Questions? Have an app that uses the JS configuration utility? Contact us!
  • What is PebbleKit JS?
  • What is the JS configuration utility?
  • How do I use it?
  • What now?
