Bezier Curves and GPaths on Pebble
  • 13 February 2015
Drawing complex paths requires a lot of manual work on Pebble. Here I'll show you how to do this efficiently and quickly using a Pebble-optimized GPath algorithm and Bezier curves.
Why Bezier Curves?
Typically, when a developer wants to create curve-based graphics on Pebble he has to use prepared bitmaps or complex GPaths (or generate paths with svg2gpath). Both of those approaches have serious downsides: bitmaps require resource space to store, memory to process and rotating bitmaps is a complex operation. Detailed GPaths, while fast in processing, can take a long time to design without special tools.
Bezier curves are a very interesting solution, which may seem computationally excessive but solves the obstacles of both the previous methods. Because they're so simple to use they are common elements in many graphic systems, primarly vector based graphics.
Drawing Bezier Curves
The mathematical formula for a Bezier curve can be found on Wikipedia. We can fairly easily turn it into C code, but we have to make a couple of important decisions. The formula itself is linear and requires us to decide how many steps we want to take in order to draw our Bezier curve. It's safe to assume that calculating 1000 points on our Bezier curve should be enough to display a continuous line on the small Pebbles screen.
void naive_bezier(GContext *ctx, GPoint points[]) {
  for (double t = 0.0; t<1.0; t += 0.001) {
    double tx = pow_d(1-t, 3) * points[0].x + 3 * t * pow_d(1-t, 2) * points[1].x +
                  3 * pow_d(t, 2) * (1-t) * points[3].x + pow_d (t, 3) * points[2].x;
    double ty = pow_d(1-t, 3) * points[0].y + 3 * t * pow_d(1-t, 2) * points[1].y +
                  3 * pow_d(t, 2) * (1-t) * points[3].y + pow_d(t, 3) * points[2].y;
    graphics_draw_pixel(ctx, GPoint(tx, ty));
Notes:
  • pow_d(double a, int b) is simply a function which returns b to the power of a.
  • points contains array of 4 points used as parameters for drawing the Bezier curve.
While this approach gives us precise results its also very computationally expensive. Most of the work done by the CPU is redundant as most of those points overlap each other due to the low screen resolution.
Optimizing for Pebble
The simplest optimization would be reducing the number of steps and drawing lines between computed points. While this will significantly reduce calculation time, it will also make the curve less precise and pleasing to the eye. But what if we could dynamically calculate the number of segments needed to create perfectly smooth curve? Here's a method published by Maxim Shermanev which you can find out more about on his website: www.antigrain.com.
Below you can see code from his research adapted to work efficiently on the Pebble architecture:
void recursive_bezier_fixed(int x1, int y1,
                            int x2, int y2,
                            int x3, int y3,
                            int x4, int y4){
  // Calculate all the mid-points of the line segments
  int x12   = (x1 + x2) / 2;
  int y12   = (y1 + y2) / 2;
  int x23   = (x2 + x3) / 2;
  int y23   = (y2 + y3) / 2;
  int x34   = (x3 + x4) / 2;
  int y34   = (y3 + y4) / 2;
  int x123  = (x12 + x23) / 2;
  int y123  = (y12 + y23) / 2;
  int x234  = (x23 + x34) / 2;
  int y234  = (y23 + y34) / 2;
  int x1234 = (x123 + x234) / 2;
  int y1234 = (y123 + y234) / 2;
  // Angle Condition
  int32_t a23 = atan2_lookup((y3 - y2) / fixedpoint_base, (x3 - x2) / fixedpoint_base);
  int32_t da1 = abs(a23 - atan2_lookup((y2 - y1) / fixedpoint_base, (x2 - x1) / fixedpoint_base));
  int32_t da2 = abs(atan2_lookup((y4 - y3) / fixedpoint_base, (x4 - x3) / fixedpoint_base) - a23);
  if(da1 >= TRIG_MAX_ANGLE) da1 = TRIG_MAX_ANGLE - da1;
  if(da2 >= TRIG_MAX_ANGLE) da2 = TRIG_MAX_ANGLE - da2;
  if(da1 + da2 < m_angle_tolerance)
    // Finally we can stop the recursion
    add_point(x1234 / fixedpoint_base, y1234 / fixedpoint_base);
    return;
  // Continue subdivision
  recursive_bezier_fixed(x1, y1, x12, y12, x123, y123, x1234, y1234);
  recursive_bezier_fixed(x1234, y1234, x234, y234, x34, y34, x4, y4);
bool bezier_fixed(GPathBuilder *builder, GPoint p1, GPoint p2, GPoint p3, GPoint p4) {
  // Translate points to fixedpoint realms
  int32_t x1 = p1.x * fixedpoint_base;
  int32_t x2 = p2.x * fixedpoint_base;
  int32_t x3 = p3.x * fixedpoint_base;
  int32_t x4 = p4.x * fixedpoint_base;
  int32_t y1 = p1.y * fixedpoint_base;
  int32_t y2 = p2.y * fixedpoint_base;
  int32_t y3 = p3.y * fixedpoint_base;
  int32_t y4 = p4.y * fixedpoint_base;
  if (recursive_bezier_fixed(builder, x1, y1, x2, y2, x3, y3, x4, y4)) {
    return gpath_builder_line_to_point(builder, p4);
  return false;
Notes:
  • This code uses fixedpoint integers since the Pebble CPU doesn't support floating point operations. You can find more about that in a talk given by Matthew Hungerford during 2014 Pebble Developer Retreat (video available here).
  • To determine the angle, the algorithm calculates parameters of the curve at given points. This implementation is very effective since Pebble's atan2_lookup is just looking up that value in a precomputed table.
  • m_angle_tolerance is the angle of the curve we're looking for, expressed in degrees. In our case it's 10 degrees: int32_t m_angle_tolerance = (TRIG_MAX_ANGLE / 360) * 10;
Applying Code to GPath
In order to make it easy for developers, we have prepared the GPathBuilder library which will ease the process of creating GPaths out of a few Bezier curves and/or lines. The resulting path can already be manipulated with the existing APIs. You can find it on the pebble-hacks Github page along with a simple demo app.
Usage is extremely simple. Here are the main functions in the API:
  • GPathBuilder* gpath_builder_create(uint32_t max_points) will create the GPathBuilder object you will need to use in order to create a GPath with Bezier curves. max_points sets the limit on number of points created in the process.
  • void gpath_builder_destroy(GPathBuilder *builder) will destroy the GPathBuilder object and free the memory it used.
  • bool gpath_builder_line_to_point(GPathBuilder *builder, GPoint to_point) will create a straight line from last point to the given point.
  • bool gpath_builder_curve_to_point(GPathBuilder *builder, GPoint to_point, GPoint control_point_1, GPoint control_point_2) will create a Bezier curve from the last point to a given point (to_point), control_point_1 and control_point_2 are used as parameters for the Bezier curve for last point and given point respectively.
  • GPath* gpath_builder_create_path(GPathBuilder *builder) will return a GPath object ready to be used in your graphic routine. Remember that the GPathBuilder is not being destroyed in the process and you have to do that manually.
Below is shown a simple shape involving two curves and the code required to create the path:
result
// Create GPathBuilder object
GPathBuilder *builder = gpath_builder_create(MAX_POINTS);
// Move to the starting point of the GPath
gpath_builder_move_to_point(builder, GPoint(0, -60));
// Create curve
gpath_builder_curve_to_point(builder, GPoint(60, 0), GPoint(35, -60), GPoint(60, -35));
// Create straight line
gpath_builder_line_to_point(builder, GPoint(-60, 0));
// Create another curve
gpath_builder_curve_to_point(builder, GPoint(0, 60), GPoint(-60, 35), GPoint(-35, 60));
// Create another straight line
gpath_builder_line_to_point(builder, GPoint(0, -60));
// Create GPath object out of our GPathBuilder object
s_path = gpath_builder_create_path(builder);
// Destroy GPathBuilder object
gpath_builder_destroy(builder);
// Get window bounds
GRect bounds = layer_get_bounds(window_get_root_layer(window));
// Move newly created GPath to the center of the screen
gpath_move_to(s_path, GPoint((int16_t)(bounds.size.w/2), (int16_t)(bounds.size.h/2)));
And there you have it, complex GPaths built with a few lines of code.
Conclusion
This library should make it easier to create amazing graphics on Pebble and can be used in animations as it's lightweight and fast. Bear in mind that the GPathBuilder temporarily uses RAM proportinal to max_points until gpath_builder_destroy is called. You can find the example app and library code on the pebble-hacks Github page.
We are also looking forward to this technology being used in online tools such as SVG to Pebble GPath Converter by awesome Pebble developer Rajendra Serber.
  • Why Bezier Curves?
  • Drawing Bezier Curves
  • Optimizing for Pebble
  • Applying Code to GPath
  • Conclusion
