This is an overview of drawing vector images using Pebble Draw Command files. See the Vector Animations tutorial for more information.
As opposed to bitmaps which contain data for every pixel to be drawn, a vector file contains only instructions about points contained in the image and how to draw lines connecting them up. Instructions such as fill color, stroke color, and stroke width are also included.
Vector images on Pebble are implemented using the Draw Commands API, which
allows apps to load and display PDC (Pebble Draw Command) images and sequences
that contain sets of these instructions. An example is the weather icon used in
weather timeline pins. The benefit of using vector graphics for this icon is
that is allows the image to stretch in the familiar manner as it moves between
the timeline view and the pin detail view:
The main benefits of vectors over bitmaps for simple images and icons are:
Smaller resource size - instructions for joining points are less memory expensive than per-pixel bitmap data.
Flexible rendering - vector images can be rendered as intended, or manipulated at runtime to move the individual points around. This allows icons to appear more organic and life-like than static PNG images. Scaling and distortion is also made possible.
However, there are also some drawbacks to choosing vector images in certain cases:
Vector files require more specialized tools to create than bitmaps, and so are harder to produce.
Complicated vector files may take more time to render than if they were simply drawn per-pixel as a bitmap, depending on the drawing implementation.
The file format of vector image files on Pebble is the PDC (Pebble Draw Command) format, which includes all the instructions necessary to allow drawing of vectors. These files are created from compatible SVG (Scalar Vector Graphics) files. Read Converting SVG to PDC for more information.
Add the PDC file to the project resources in package.json with the
'type' field to raw:
"media": [
"type": "raw",
"name": "EXAMPLE_IMAGE",
"file": "example_image.pdc"
Drawing a Pebble Draw Command image is just as simple as drawing a normal
PNG image to a graphics context, requiring only one draw call. First, load the
.pdc file from resources as shown below.
First, declare a pointer of type GDrawCommandImage at the top of the file:
static GDrawCommandImage *s_command_image;
Create and assign the GDrawCommandImage in init(), before calling
window_stack_push():
// Create the object from resource file
s_command_image = gdraw_command_image_create_with_resource(RESOURCE_ID_EXAMPLE_IMAGE);
Next, define the LayerUpdateProc that will be used to draw the PDC image:
static void update_proc(Layer *layer, GContext *ctx) {
// Set the origin offset from the context for drawing the image
GPoint origin = GPoint(10, 20);
// Draw the GDrawCommandImage to the GContext
gdraw_command_image_draw(ctx, s_command_image, origin);
Next, create a Layer to display the image:
static Layer *s_canvas_layer;
Assign the LayerUpdateProc that will do the rendering to the canvas
Layer and add it to the desired Window during window_load():
// Create the canvas Layer
s_canvas_layer = layer_create(GRect(30, 30, bounds.size.w, bounds.size.h));
// Set the LayerUpdateProc
layer_set_update_proc(s_canvas_layer, update_proc);
// Add to parent Window
layer_add_child(window_layer, s_canvas_layer);
Finally, don't forget to free the memory used by the sub-components of the
Window in main_window_unload():
// Destroy the canvas Layer
layer_destroy(s_canvas_layer);
// Destroy the PDC image
gdraw_command_image_destroy(s_command_image);
When run, the PDC image will be loaded, and rendered in the LayerUpdateProc.
To put the image into contrast, optionally change the Window background
color after window_create():
window_set_background_color(s_main_window, GColorBlueMoon);
The result will look similar to the example shown below.
