    • Creating Pebble Packages
    • Using Pebble Packages
Getting started
Using pebble packages is easy:
  1. Find a package. We will have a searchable listing soon, but for now you can browse the pebble-package keyword on npm.
  2. Run pebble package install pebble-somelib to install pebble-somelib.
  3. Use the package.
It is possible to use some standard npm packages. However, packages that depend on being run in node, or in a real web browser, are likely to fail. If you install an npm package, you can use it in the usual manner, as described below.
C code
Packages should document their specific usage. However, in general, for C packages you can include their headers and call them like so:
#include <pebble-somelib/somelib.h>
int main() {
  somelib_do_the_thing();
All of the package's include files will be in a folder named after the package. Packages may have any structure inside that folder, so you are advised to read their documentation.
Notice
Tip: If you want to use an Event Service, you should use the pebble-events package to avoid conflicting with handlers registered by packages.
JavaScript code
JavaScript packages are used via the require function. In most cases you can just require the package by name:
var somelib = require('pebble-somelib');
somelib.doTheThing();
Resources
If the package you are using has included image resources, you can reference them directly using their RESOURCE_ID_* identifiers.
static GBitmap *s_image_01;
s_image_01 = gbitmap_create_with_resource(RESOURCE_ID_MEDIA_PACKAGE_IMAGE_01_TINY);
Published Media
If the package you are using has defined publishedMedia resources, you can either reference the resources using their resource identifier (as above), or you can create an alias within the package.json. The name you specify in your own project can be used to reference that publishedMedia item for AppGlances and Timeline pins, eg. PUBLISHED_ID_<name>
For example, if the package exposes the following publishedMedia:
"resources": {
  "publishedMedia": [
      "name": "MEDIA_PACKAGE_IMAGE_01",
      "glance": "MEDIA_PACKAGE_IMAGE_01_TINY",
      "timeline": {
        "tiny": "MEDIA_PACKAGE_IMAGE_01_TINY",
        "small": "MEDIA_PACKAGE_IMAGE_01_SMALL",
        "large": "MEDIA_PACKAGE_IMAGE_01_LARGE"
You could define the following name and alias with a unique id in your package.json:
"resources": {
  "publishedMedia": [
      "name": "SHARED_IMAGE_01",
      "id": 1,
      "alias": "MEDIA_PACKAGE_IMAGE_01"
You can then proceed to use that name, prefixed with PUBLISHED_ID_, within your code:
const AppGlanceSlice entry = (AppGlanceSlice) {
  .layout = {
    .icon = PUBLISHED_ID_SHARED_IMAGE_01,
    .subtitle_template_string = "message"
  • Getting started
  • C code
  • JavaScript code
  • Resources
  • Published Media
