    • App Metadata
    • Color Picker Tool
    • Command Line Tool
    • Developer Connection
    • Hardware Information
Color Picker Tool
Click a hexagon in the color map to see its SDK constant and how to use it in your Pebble app.
Uncorrected
Sunlight
Name:
Sample:
HTML code:
Uncorrected HTML code:
SDK Constant:
Code (RGB):
Code (Hex):
Example Code Segment
See the Images guide to get compatible palette files for popular image editing programs.
