The Road to Pebble SDK 3.0 in Ten Questions
  • 03 April 2015
We launched the first version of our new SDK with support for Pebble Time two days into our Kickstarter campaign. Since then, we have updated it every week, releasing six iterations of our developer preview. Some of these versions included major new features like support for color in the emulator and support for the timeline. Some other features were more subtle, like the new antialiased drawing mode and the updates to the animation system. All these changes together, and a bunch more that you have not seen yet, will form the SDK that you will use to build watchfaces, watchapps and timeline apps for all models of Pebble watches in the coming months.
These updates include lots of changes, and no matter how hard we try to document everything there are a lot of unanswered questions. Some subjects have just not been addressed by the developer previews yet, some need more explaining and as always there are things we just missed in our communication efforts.
In this update, I want to answer publicly the most frequent questions received from the community in the last few weeks. I will cover components that have been released but also those that are still to come so you have the information needed to plan ahead and prepare your apps for the Pebble Time launch.
What is the “timeline” shown in the Kickstarter video and how can I plug into it?
The timeline is a system-provided app that allows the user to navigate through important events in their near future and their past.
A glipse at the future (on the timeline)
Apps have a very important role to play in the timeline. All Pebble apps (but not companion apps that use our native PebbleSDK on Android and iOS) can push “pins” to the timeline. From a developer perspective, pins are just a block of JSON which describes the information to show to the user and what layout to use to display the information (generic, calendar, sports or weather). Pins can also include notifications that will be shown to the user when the pin is created or updated on the watch, and reminders that can trigger at a specific time. Finally pins can have actions attached to them. Actions can open a Pebble app with a uint32 parameter.
You can experiment with pins in CloudPebble’s new “Timeline” tab or with the command line SDK and the pebble insert-pin command. For documentation, refer to our “Understanding Timeline Pins” guide. Once you have nailed down what you want your pins to look and feel like you can start pushing them via a public HTTP API. This API requires that your app is submitted on the Pebble appstore; that is also how you get your API key to use the timeline API. We have built a Node.js library to make this easier and David Moreau has already shared a PHP library.
We also have a number of examples to help you get started:
  • A very simple timeline hello world that shows how to push a pin every time you press a button in your app
  • A TV show tracker that announces your favorite tv show and lets users click on the pins to increase the number of viewers in realtime.
Get started now with our Getting started with Timeline post or join us at the next Pebble SF developer meetup on April 24th where we will do a walkthrough of how to build a timeline app. If you are unable to make it, you can also find this session on our YouTube channel.
As a side note, many people have asked us what will happen if their app does not integrate with the timeline. The new Pebble system still includes a main menu in which all the apps will appear and they can be still be launched from there.
How can I build apps with transitions and animations like the ones shown in the Kickstarter videos?
The user interface in the new OS is full of extremely rich animations, and of course we are not limiting them to the system applications. We want all apps to take advantage of them and to achieve that, we are investing a lot of effort.
An essential part of all the animations is the core graphics framework used to draw shapes, text and images. We have improved it a lot in recent weeks with much better support for animations, anti-aliasing and stroke width, color bitmap handling and a lot of bugfixes and performance improvements.
Upcoming releases of the SDK will add the new UI components that you saw in the Kickstarter video:
  • A new MenuLayer with support for color, infinite scrolling (i.e. looping back to the top), and new animations The new MenuLayer
>{pebble-screenshot,pebble-screenshot--time-red}
  • A new ActionBar (available this week in developer preview 6!) that is wider, takes the full height of the screen, and includes some new animations. The
updated ActionBar
  • An ActionMenuWindow which is a full screen component to select an action in a list. This is the same UI used to select an action on a pin or a notification, and it is available to all apps. The new ActionMenuWindow
  • A StatusBarLayer that gives you much more control over the status bar, including the ability to animate it and add goodies like a progress indicator and a card counter for the card pattern. The new StatusBar
  • Cards are not really a UI Component but more of a standard pattern, seen in the Weather app in the Kickstarter video and we expect that a lot more apps will want to re-use it because it is an extremely efficient way to represent information and looks very good! We will have a full example available to you very soon showing how to build this type of app. A preview of the Weather
app and its animations
For more information on the design of apps in SDK 3.0, we are putting the finishing touches on a completely new design guide. Stay tuned!
What is up with the icons on Pebble Time? Can I use these effects in my applications?
A lot of the new design aesthetic is provided by icons, and those icons are not your usual bitmap file. They animate during transitions to give a level of life and personality never seen in any User Interface framework before.
They are vector based animations and we came up with a complete new set of APIs called Pebble Drawing Commands, as well as a new file format (.pdc) to implement them. Compared to bitmap icons they can be automatically animated by the system depending on the context: the same icon can explode on the screen, regroup into a dot or fly through one of the screen edges; all of this in a fraction of the space it would normally take to do such effects with animated PNGs.
We will be providing a large set of icons that you can use in your timeline pins and in your apps. You will also be able to make your own animated icons to play in your app.
What is really happening when I compile an app today to be compatible with all Pebbles?
With the current version of the Pebble SDK, we compile your apps once with SDK 2.9 for Aplite (Pebble and Pebble Steel) and once with SDK 3.0 for Basalt (Pebble Time and Pebble Time Steel). This means that your apps can have a different look on each platform. This is going to be even more true as we introduce the new UI components in the next few releases.
Aplite differences
However, as soon as we provide official support for Aplite in SDK 3.0, we will start compiling against the same set of APIs and the UI components will have similar sizes, look and behavior.
All the new software features of Pebble Time will be available on the original Pebble, including the timeline, as well as the new UI components, PNG, Pebble Drawing Commands, unlimited apps, AppFaces, etc. Of course features that are hardware-dependent (such as the microphone) will not be supported on Aplite.
We encourage everyone to maintain support for both Aplite and Basalt in their source code. You can easily do it with #ifdef calls. If you just want to freeze your Aplite app as it is today and focus on your Basalt app this will be possible too with a new feature in the build process coming in the near future.
What are AppFaces and when can we use them?
AppFaces are previews of your app that are displayed in the launcher before the user starts your app. To use them, your app will need to support being launched without a UI to update the AppFace.
AppFaces
AppFaces will not be part of Pebble SDK when we launch Pebble Time. Your apps will just appear with their name until we add this API at a later stage. This also means that your app icons defined in the appinfo.json are not used with the new launcher (but they will still appear on Aplite until 3.0 ships for Aplite).
When can we start interacting with smartstraps?
We have released a lot of mechanical and electrical information about smartstraps but no APIs yet. You will quickly find out that without software support, the smartstrap does not get any power.
We are working hard with our first smartstrap partners to finalize the specifications for this API. If you want to be a part of this discussion, please make yourself known!
How can I get my hands on Pebble Time? When will users get them?
If you did not order one on Kickstarter you can register on our website to be notified as soon as they are available for normal orders. We will ship every Kickstarter pledge before we start selling them on the Pebble website. If you ordered one through the Kickstarter campaign, we are working hard to get it to you as soon as possible.
As you know if you are a Kickstarter backer, Pebble Time starts shipping in May.
As a developer, you already have access to the emulator. It includes everything you need to work on your app. If you are missing anything, contact us. With only about a month left, there is no time to lose!
What about PebbleKit for iOS and Android? Any improvements?
We decided to focus all our efforts on the new UI framework and the timeline. There are no functional changes to PebbleKit in SDK 3.0. However, all Android apps must be recompiled with the new PebbleKit Android library to be compatible with Pebble Time. If you do not recompile, your app will not work with Pebble Time.
We have lots of plans for PebbleKit in the future and hope to share them with you soon.
If you have suggestions for APIs you’d like to see, please contact us
Will developers have access to the microphone? What can we do with it?
Absolutely. We will give developers access to our speech-to-text APIs. You will be able to show a UI to start a recording and your app will receive the text spoken by the user. This API is coming soon™ - not in 3.0.
We are considering other APIs such as direct microphone access. Stay tuned for more information on those.
Can we submit apps for Pebble Time to the Pebble appstore now?
No, you should not. As long as you are using a developer preview SDK, the APIs are non-final and apps built with the developer preview SDK may not work with the final firmware and SDK shipped with Pebble Time.
Once the APIs are stable, we will announce a final SDK and encourage everyone to push applications built with the final SDK to the Pebble appstore.
Want more answers?
For more questions and answers, such as the future of the InverterLayer, information on floating point support or whether Pebble is really powered by unicorns and rainbows, please take a look at this /r/pebbledevelopers thread.
Much thanks to all the developers who contributed questions to prepare this blog post!
If there is anything else you would like to know, this thread is just one of the many ways to get in touch with us and get answers!
  • What is the “timeline” shown in the Kickstarter video and how can I plug into it?
  • How can I build apps with transitions and animations like the ones shown in the Kickstarter videos?
  • What is up with the icons on Pebble Time? Can I use these effects in my applications?
  • What is really happening when I compile an app today to be compatible with all Pebbles?
  • What are AppFaces and when can we use them?
  • When can we start interacting with smartstraps?
  • How can I get my hands on Pebble Time? When will users get them?
  • What about PebbleKit for iOS and Android? Any improvements?
  • Will developers have access to the microphone? What can we do with it?
  • Can we submit apps for Pebble Time to the Pebble appstore now?
  • Want more answers?
